ProjeQtOr free project management software - Move the Notes DIV part to be on its own, rather than in a column - ProjeQtOr
29 Aug 2018 02:57 #1 by iconic
Is there anyway I can set the Notes DIV section of ProjeQtor to actually display under all other columns and take the whole width of all three columns.
I am asking if this is possible, because when it is part of a column (we have large screens) and use 3 columns, the notes part is rather small in width and reading the notes can sometimes means we have to scroll horizontally when images are added in the notes or large tables are added.
It would be great if we can, somehow move the notes to be displayed under all 3 columns and to have the wider width to be able to read it with ease.
29 Aug 2018 08:26 #2 by babynus
No, there is no easy way to do this
29 Aug 2018 08:47 #3 by Envergus
There is no way to do it without changing the code as babynus said (since he is the creator he knows better).
but to help you this may be a quick solution (I did it because I have a longitudinal screen):
find the following lines in /view/objectMain.php:
<?php if (property_exists($objectClass, '_Note')) {?>
<div id="detailRightDiv" dojoType="dijit.layout.ContentPane" region="right" splitter="true" style="width:<?php echo $rightWidth;?>">
and change region="right" to region="bottom"
cheers
29 Aug 2018 08:58 #4 by babynus
YEP, good workoround.
Attention, it will bring any part on right to the bottom, not only notes...
29 Aug 2018 09:04 #5 by iconic
How can I use that and just have Notes move to the bottom.
29 Aug 2018 09:08 - 29 Aug 2018 09:10 #6 by Envergus
Try it and if you find any inconvenience you can restore it back as it was and it wont affect your data.
Last edit: 29 Aug 2018 09:10 by Envergus.
