ProjeQtOr free project management software - Move the Notes DIV part to be on its own, rather than in a column - Page 4 - ProjeQtOr
29 Aug 2018 16:08 - 29 Aug 2018 16:10 #19 by Envergus
that is because you pull it too much to the left
Last edit: 29 Aug 2018 16:10 by Envergus.
29 Aug 2018 16:13 #20 by iconic
Found the activity stream. Thank you for that.
29 Aug 2018 16:14 #21 by iconic
With the white screen showing that error message I can't seem to find where on the left side it is to pull it back to its original place.
See attached image
29 Aug 2018 16:40 #22 by iconic
I worked it out.
I had to close the menu part on the far left to very small, which then showed the Activity Stream and I was able to pull it back to the right.
All fixed now.
