ProjeQtOr free project management software - Move the Notes DIV part to be on its own, rather than in a column - Page 3 - ProjeQtOr
29 Aug 2018 15:10 #13 by babynus
I understand better now.
Solution of Envergus is correct as he moves the Stream part, which displays notes:woohoo:
So it is exactly what you expect, you can then just hide (collapse) the notes.
29 Aug 2018 15:23 #14 by iconic
I have tried to do this and made the changes that were said but the Notes still remains in the right column in its small width?
I can't seem to work out what I am doing wrong.
29 Aug 2018 15:33 #15 by Envergus
can you see the stream window? if not, would you send a screen shot of the whole screen? what is your Projeqtor version?
29 Aug 2018 15:54 #16 by iconic
Version I have is 7.1.4
See attached Image for Whole Screen.
29 Aug 2018 16:04 - 29 Aug 2018 16:10 #17 by Envergus
You still have the stream part at right. See the attachment and put the cursor inside the green circle (but on your screen) and pull it to the left then you must see the stream window.
Last edit: 29 Aug 2018 16:10 by Envergus.
29 Aug 2018 16:07 #18 by iconic
I now have a new problem.
When I click on the Activities TAB don't see the activities anymore.
I only see this response "No Activity selected."
But it shows a white Screen with only the menus.
