ProjeQtOr free project management software - v2.2.0:: AutoMail Issue - Page 2 - ProjeQtOr
02 Aug 2012 18:22 - 02 Aug 2012 18:22 #7 by babynus
Replied by babynus on topic Re: v2.2.0:: AutoMail Issue
which Lotus client : heavy java one or webmail ?
Last edit: 02 Aug 2012 18:22 by babynus.
03 Aug 2012 08:25 #8 by gvecchi
Replied by gvecchi on topic Re: v2.2.0:: AutoMail Issue
Java one, version 8.5.3 but database version 7.0.3
03 Aug 2012 09:26 #9 by babynus
I re-opened ticket #694.
I will have some tests.
03 Aug 2012 09:31 #10 by gvecchi
Do you need additional infos?
03 Aug 2012 11:33 #11 by babynus
I tested from test database, and all is working fine.
You should have received this mail : can you check it is correcly formatted ?
If so, then you have an issue with your smtp mail server used by PHP : check its configuration.
If display is wrong, you may check configuration of your mailbox server of mail client.
Here are correct display of received email :
With Lotus client :
With Outlook client :
03 Aug 2012 11:38 #12 by gvecchi
I received your email (see attachment) and it is good.
If the problem is in my smtp server, why your email is good (the server that delivered your email to me and the smtp server I use for projector ria is the same)?
