ProjeQtOr free project management software - v2.2.0:: AutoMail Issue - Page 4 - ProjeQtOr
09 Aug 2012 09:27 #19 by babynus
Replied by babynus on topic Re: v2.2.0:: AutoMail Issue
gvecchi wrote: Do you mean files/config/parameters.php or tool/parameters.php ?
I mean parameter file defined in /tool/parametersLocation.php. By default it is /files/config/parameters.php, but it is advised to changes its location (to put it out of web access).
09 Aug 2012 09:58 #20 by gvecchi
Replied by gvecchi on topic Re: v2.2.0:: AutoMail Issue
I set $paramMailEol in files/config/parameters.php but it doen's work.
09 Aug 2012 11:09 #21 by babynus
With V2.4.2 or V2.4.3 ?
09 Aug 2012 11:24 #22 by gvecchi
2.3.0
09 Aug 2012 11:57 - 09 Aug 2012 11:57 #23 by babynus
Normal it does not work : implementation comes with V2.4.2... :whistle:
Last edit: 09 Aug 2012 11:57 by babynus.
09 Aug 2012 12:00 #24 by gvecchi
I modified also tool/projector.php as you typed. I thought it do the trick, isn't it?
