ProjeQtOr free project management software - v2.2.0:: AutoMail Issue - Page 5 - ProjeQtOr
09 Aug 2012 14:31 #25 by babynus
Replied by babynus on topic Re: v2.2.0:: AutoMail Issue
Yes, it should.
Could you try to add a debug line :
[code type=php-brief]if (!$headers) {
$eol=(isset($paramMailEol))?$paramMailEol:"\r\n";
debugLog("NewLine=".strlen($eol).":".nin2hex($eol));
$headers = 'MIME-Version: 1.0' . $eol;
$headers .= 'Content-type: text/html; charset=utf-8' . $eol;
$headers .= 'From: ' . (($sender)?$sender:$paramMailSender) . $eol;
$headers .= 'Reply-To: ' . (($sender)?$sender:$paramMailReplyTo) . $eol;
$headers .= 'Content-Transfer-Encoding: 8bit' . $eol;
$headers .= 'X-Mailer: PHP/' . phpversion();
}[/code]
Then try again a copy here the log file.
09 Aug 2012 14:46 - 09 Aug 2012 14:51 #26 by gvecchi
Replied by gvecchi on topic Re: v2.2.0:: AutoMail Issue
If I append debug line, page hung trying sending mail notification (ex when assigne a task) and if I modify tool/projector.php
$eol=(isset($paramMailEol))?$paramMailEol:"\n";
it works.
Last edit: 09 Aug 2012 14:51 by gvecchi.
09 Aug 2012 16:16 - 09 Aug 2012 17:21 #27 by babynus
Sorry there was a typo in the debug line :
debugLog("NewLine=".strlen($eol).":".bin2hex($eol));
I just found the issue, line 561 must be completed:
global $paramMailSender, $paramMailReplyTo, $paramMailSmtpServer, $paramMailSmtpPort, $paramMailSendmailPath, $paramMailEol;
You can remove the debug line !
Then it should work.
I include this fox in next version, so if you change it, you'll retrieve your parametering on next versions.
Last edit: 09 Aug 2012 17:21 by babynus.
The following user(s) said Thank You: gvecchi
09 Aug 2012 16:25 #28 by gvecchi
Yeah man, now it works ;)
04 Sep 2012 07:57 #29 by gvecchi
I see that stable version 2.4.3 misses that line: isn't your "next" version 2.4.3 or do you miss it?
04 Sep 2012 09:32 #30 by babynus
The fix appears in V2.5.0.
V2.4.3 was published on august 7th, 3 days before the identification of the fix.
