ProjeQtOr free project management software - [SOLVED] Project Product link problem - Page 2 - ProjeQtOr
[SOLVED] Project <> Product link problem
09 Apr 2021 23:07 - 09 Apr 2021 23:08 #7 by Tony44
Yes, strange.
babynus post=30127
I tried again and there is not issue to check / uncheck link.
Checkbox is readonly only when version is closed.
Of course, this is not a general anomaly of the application but specific to our database or configuration, see my 1st post :
I do not reproduce these behaviors on another test installation of ProjeQtOr, nor on demo.projeqtor.org.
babynus post=30127
Maybe you can delete the link and re-create it.
Remove link is useless: the box is automatically checked for all new links, including a new version and a new project.
Can this be caused by an error in the database ?
Thanks for your help
Tony44
Last edit: 09 Apr 2021 23:08 by Tony44.
13 Apr 2021 13:51 #8 by babynus
Just re-reading the full post, I noticed the Version used (1-0) is closed.
This may explain the behavior
13 Apr 2021 22:46 - 13 Apr 2021 22:50 #9 by Tony44
No problem for closed versions, for which the project-version relationship is necessarily closed.
The issue is for unclosed versions.
It occurs for all versions of all products and on all projects.
Example:
  • I am creating a new project.
  • I am creating a new product.
  • I am creating a new version on this product.
  • I associate the product with the project.
  • The project-version relationship is immediately closed by the system.
  • It is not possible to reopen the project-version relationship.
Tony44
Last edit: 13 Apr 2021 22:50 by Tony44.
14 Apr 2021 08:52 #10 by babynus
I don't know what can cause this behavior as I do not reproduce.
I just tried use case on demo, and all works fine.
You can have a look on demo (connect as manager) on project 'PROJECT'.
Can you please try and reproduce your use case on demo ?
14 Apr 2021 10:08 #11 by Tony44
Indeed, the issue cannot be reproduced on demo.projeqtor.org, as I indicated in my 1st post :
The problem is specific to our database, that's why I suspect an error in the database.
What can I provide to help identify the source of the problem?
Thank you again for your help
Tony44
14 Apr 2021 17:27 #12 by babynus
Only solution would be to send us a dump (possibly anonymized) of your DB, for us to analyse.
But this is out of scope of free community support.
