ProjeQtOr free project management software - [SOLVED] Project Product link problem - Page 3 - ProjeQtOr
[SOLVED] Project <> Product link problem
15 Apr 2021 00:38 #13 by Tony44
Ok I understand, thanks
Tony44
19 Apr 2021 16:23 #14 by babynus
Luky you !
I found the issue.
Will be fixed in V9.1.3
20 Apr 2021 22:54 #15 by Tony44
Very good news
Did you finally reproduce the issue ?
Thanks for the information
Tony44
21 Apr 2021 09:07 #16 by babynus
Yes, I reproduced the issue...
... and fixed it.
Fix will be deployed in V9.1.3.
09 May 2021 23:59 #17 by Tony44
We have installed version 9.1.3 and the issue is fixed.
Thanks again
Tony44
