ProjeQtOr free project management software - [SOLVED] Project Product link problem - ProjeQtOr
[SOLVED] Project <> Product link problem
05 Apr 2021 20:53 #1 by Tony44
I am asking for your help with a problem for which I am unable to identify the cause.
When linking a product to a project, I notice these unexpected behaviors :
  • The project <> product version links, created automatically, are directly and systematically "closed".
  • If I try to uncheck "closed" on these links, the system does not save any changes and the link remains "closed".
  • The product is not offered in the "Product" list of the elements of this project (for example on the tickets), although this is the desired objective.
I see this for any project and product.
The affected products and product versions are not closed.
These issues are seen on ProjeQtOr V9.0.6, but I don't think the version or the app is to blame.
These actions do not produce an error in the logs.
In the past, it worked fine on this same basis.
I do not reproduce these behaviors on another test installation of ProjeQtOr, nor on demo.projeqtor.org.
What setting could be causing this problem ?
Could this be caused by an error in the database ? If yes, what to do ?
If not, what do you advise me to do to try to fix this ?
Tony44
06 Apr 2021 12:42 #2 by babynus
It is not the links that are closed, it is the versions.
06 Apr 2021 22:55 #3 by Tony44
Thanks for the reply.
Unfortunately no, the product versions are not closed :
When the product version is closed, the project <> version link is locked closed (the closed box is checked and grayed out) :
Here it is not the case, I can uncheck "closed" on the link project <> version, but when validating the system indicates that there is nothing to save and check the box again :
Do you have another idea ?
Tony44
08 Apr 2021 21:00 #4 by babynus
I don't understand where is the issue.
You have close property on Version and on Project-Version relationship.
If Project-Version relationship is closed, you cannot use the version on the project.
if Version is closed, all its Project-Version relationship are also automatically closed.
08 Apr 2021 21:56 - 08 Apr 2021 21:58 #5 by Tony44
Yes, I understood the expected behavior
The issue is that we cannot uncheck the close property on project-version relationship.
This for some unknown reason (the version is not closed)
Tony44
Last edit: 08 Apr 2021 21:58 by Tony44.
09 Apr 2021 16:36 #6 by babynus
Strange.
I tried again and there is not issue to check / uncheck link.
Checkbox is readonly only when version is closed.
Maybe you can delete the link and re-create it.
