ProjeQtOr free project management software - [SOLVED] Empty project automaticaly created after activity creation - Page 3 - ProjeQtOr
22 Mar 2019 08:40 #13 by babynus
I already have made direct change on the database.
:evil:
This is always a bad idea.
But after each, It work fine.
Side effects may appear later, possibly with new feature.
The framework expects some structure, that is not forced by DB model.
If you don't respect this, you may get unexpected behavior.
Try and apply consistency checks, on administration screen.
This may fix somet things.
But, as we don't know what you did on DB, possibly consistency fix will remove some data you consider valid.
So be sure to backup DB before consitency fix.
22 Mar 2019 15:53 #14 by babynus
A fix has been found for "long duration" when ceating an activity.
It will be deployed on V7.4.4
Patch is attached.
The following user(s) said Thank You: LaurentCap
24 Mar 2019 12:28 #15 by LaurentCap
I apply consistency check in administrator scrren and It make no changes. Activity creation takes 60 seconds.
But always update time on all the project changes instead of creating one.
Regarding the update date on project, I notice that the older is on the project at the most lower level.
Like the update apply on the project at the lower level and after the higher level and so on.
After applying fix It seems to takes more time (nearly 80 seconds).
Have you some other things that I can check ?
Thanks for your help.
A daily ProjeQt'Or user.
24 Mar 2019 13:16 - 24 Mar 2019 13:17 #16 by babynus
Check last reply : patch proposed.
Last edit: 24 Mar 2019 13:17 by babynus.
25 Mar 2019 11:03 #17 by LaurentCap
Babynus,
I applied the patch and no changes was made. Always 60 seconds on Activity creation.
I continue to check idProject and refId + refType on all the tables.
Is it important to delete record of non-existing element in the tables history, kpihistory and kpivalue ?
25 Mar 2019 16:28 #18 by babynus
Patch was not complete.
Good one is attached.
The following user(s) said Thank You: Bena
