ProjeQtOr free project management software - [SOLVED] Empty project automaticaly created after activity creation - ProjeQtOr
19 Mar 2019 16:08 #1 by LaurentCap
Since I upgraded to V7.4.3 I encounter 2 linked problems :
1 - When I create an Activity I wait for a very long time (almost 40 seconds) before having access to the window of the created activity
2 - When I do the point 1, An empty project is automaticaly created
I've looked in the log file but nothing appears during this operation.
I've clean my browser cache and It's the same.
To notice : without too much thinking I've changed the auto-increment in the table project and when I create a new Activity the empty project take the auto-increment before my update.
Please help me.
A ProjeQt'Or daily user
19 Mar 2019 23:59 #2 by babynus
Very strange behavior, I never faced.
Can you try and reproduce on Demo, to try and get a testable use case ?
20 Mar 2019 09:16 - 20 Mar 2019 09:18 #3 by LaurentCap
Try to reproduce the case on demo version = impossible
I try without hope. I think there is a record in a table wich is read when I save the activity to create it.
And this record implies a project creation.
I think about that because of the time taked by the creation process (about 50 seconds).
Could you tell me what are the table used in the project creation process ?
Thanks for your help.
Regards.
A daily ProjeQt'Or user.
Last edit: 20 Mar 2019 09:18 by LaurentCap.
20 Mar 2019 09:34 - 20 Mar 2019 09:35 #4 by LaurentCap
Hi again,
I change the sub-project association of a project and it also create a new empty project.
See below the record created in the project table :
"1041",,NULL,NULL,NULL,NULL,NULL,NULL,"0","10","0",NULL,NULL,NULL,"00017",NULL,"OPE",NULL,NULL,NULL,NULL,NULL,NULL,"0",NULL,NULL,"0",NULL,NULL,NULL,NULL,NULL,NULL,"0","2019-03-20 09:27:19",NULL,"0","0",NULL,"0",NULL,"0","0"
Hope it helps
Regards.
Last edit: 20 Mar 2019 09:35 by LaurentCap.
20 Mar 2019 10:47 - 20 Mar 2019 10:47 #5 by LaurentCap
Hi again,
I test some cases :
1 - Changing sub-project from root to an internal "structure" project
=> It takes 80 seconds and create a new empty project
2 - Changing sub-project from an internal "structure" project to root
=> It takes 5 seconds and don't create any new empty project
3 - Changing sub-project from an internal "structure" project to another internal "structure" project
=> It takes 10 seconds and don't create any new empty project
The problem seems to be in the fact of descending the project in the "structure"
I try to create an Activity when the project is on sub-project root and It takes 67 seconds instead of 80 but create a new empty project.
Hope It helps.
Regards.
Last edit: 20 Mar 2019 10:47 by LaurentCap.
20 Mar 2019 11:34 #6 by LaurentCap
Hi again,
To be the most complete in my tests, I do creation of all the element according to a project and look at the result :
Activity : 60 seconds and a new empty project
Milestone :60 seconds and a new empty project
Meeting : 60 seconds and a new empty project
test session : 60 seconds and a new empty project
all the rest takes 5 seconds and don't create a new empty project.
Hope it helps.
Regards.
