ProjeQtOr free project management software - Screens customization - Delete custom field - ProjeQtOr
25 May 2016 08:52 #1 by ndusch
I have Projeqtor version 5.3.3 and Screens customization plugin version 1.2. I created a custom filed with the screens customization plugin and now I'm trying to delete it using the delete button but I cannot. The custom field remains present and there is no error in the Projeqtor log file.
26 May 2016 08:40 #2 by babynus
Issue confirmed.
Seems to be some regression.
Ticket #20.88 Will be fixed asap.
28 May 2016 12:22 #3 by babynus
Strange, because I reproduced once, but cannot reproduce any more.
Maybe it is a specific use case, that I reproduced once by chance, but cannot reproduce any more.
You you please give more details on use case :
- browser used (with version)
- description of created field (name, caption, format, length, ....)
- search for browser issue (in browser console) where error occurs.
30 May 2016 15:18 #4 by ndusch
Indeed strange behaviour. But I don t think that browser is the cause root. (Used browser is Firefox 46.0.1)
1rst created field :
- field name : tst
- format : reference
- lenght : 12
2nd created field :
- field name : interimActions
- format : mediumtext
- lenght : 16777215
Both can not be deleted.
Is there a way to uninstall the plugin and to come back to the standard screen layout?
ND
30 May 2016 22:43 #5 by babynus
Still cannot reproduce.
Which item do you upgrade ?
To reset the item is not so easy as it involved change in database but it is a very good idea and plugin will be upgraded to add this feature.
Maybe if I can reproduce the issue you point out, I'll try I deploy new feture with fix.
11 Jun 2016 16:24 #6 by babynus
I still cannot reproduce, even if I think I could during first test when you reported the issue.
Could you please give more information :
- did you clean browser cache ?
- do you have any error in the browser console ?
- does the confirmation pop-up appears or not ?
Thanks in advance for your information that will help solve the issue.
