ProjeQtOr free project management software - Screens customization - Delete custom field - Page 2 - ProjeQtOr
11 Jun 2016 18:25 #7 by ndusch
Hi Babynus,
I tried to delete from several computers. So Ithink there is no problem from browser cache.
There is no error in browser console.
Yes every time when I try to delete the fields, the pop-up confirmation appears.
I will try to reimport the sql database in a new installation of Projeqtor to check if the field can be deleted (We use MSQLDumper for making backups)
ND
11 Jun 2016 19:20 #8 by babynus
I will soon deploy new version of screenCustomization plugin that will allow to reset a screen to standard.
I was waiting for a hint to reproduce your issue before deplyment, but if I get no clue to find a fix, I will deplaoy as is...
12 Jun 2016 15:16 #9 by ndusch
Hi
I created a new database and reimported the backup of the former database.
Deleted fields disappered in the new database!!!! Good news others customed fields were kept!
I hope it can help you.
ND
12 Jun 2016 16:04 #10 by babynus
Could you detail what you did ?
You said you reimported backup of database...
When did you make the backup ? Before creating fields you want to delete ?
It seems strange that other custom fields were kept...
Maybe they are visible, but did you try to save data into these fields ?
17 Jun 2016 18:25 #11 by ndusch
Hello Babynus,
In which database are located the customed fields?
Is this database accessible?
ND
17 Jun 2016 18:27 #12 by babynus
The custom fields are stored in the current database, on the dedicated table for each object.
NB : version 2.0 of plugin hjas just been deployed. This version allows to reset screen to default disposition ;)
