ProjeQtOr free project management software - Screens customization - Delete custom field - Page 3 - ProjeQtOr
18 Jun 2016 10:43 #13 by ndusch
Hello Babynus,
Thanks for your information.
BUT the plugin does not remove fields and custom labels from the screens.
Dont worry. I removed fields from the database and in the directory model/custom I removed the custom php file. Now I came back to the standard screen.
Thanks for your advices.
ND
18 Jun 2016 12:08 #14 by babynus
Did ypu try the new version 2.0 of the plugin ?
It integrates new "reset" feature that resets the screen to its default standard disposition.
If you faced issues with this new feature, please describe use case so that we can try and fix it.
27 Jun 2016 22:12 #15 by ndusch
Hi Babynus
Yes I did the update to version 2.0. But I met the same situation as before.
When I pushed the delete button a pop up menu appeared to prevent the deletion but afterwards nothing happen!
So I decided to cancel manually thefields in the database and the php files.
Sorry for this bad news.
ND
07 Jul 2016 19:39 #16 by babynus
Issue finaly found and fixed.
It was linked to community version, under some PHP versions.
V5.4.2 fixes the issue.
08 Jul 2016 14:00 #17 by ndusch
Babynus,
Excellent. It works.
Thank you.
Reagrds,
ND
