ProjeQtOr free project management software - ValidatedWork reset - ProjeQtOr
ValidatedWork reset
01 Oct 2015 14:43 #1 by fdoucet
ValidatedWork reset was created by fdoucet
We have a problem with the validatedwork on activity, when i put a decimal value, the value is reseted when i but entire value there are no problem.
We have this problem with unix and mysql but when i try to reproduce the same problem on my computer with a local instance the value is not reseted.
Have you an idea for the problem?
Project V5.0.5
03 Oct 2015 11:07 #2 by babynus
Replied by babynus on topic ValidatedWork reset
Please check log file : it may contain hints.
05 Oct 2015 08:19 #3 by fdoucet
Replied by fdoucet on topic ValidatedWork reset
hello,
this is the log file when save validated work
2015-10-05 08:17:02.504 ..... SCRIPT .... XXX.XXX.XXX.XXX /tool/saveObject.php
2015-10-05 08:17:02.505 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=saveObject.php
2015-10-05 08:17:02.609 ..... SCRIPT .... XXX.XXX.XXX.XXX SqlElement::setReference
2015-10-05 08:17:07.585 ..... SCRIPT .... XXX.XXX.XXX.XXX /tool/jsonQuery.php
2015-10-05 08:17:07.585 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=jsonQuery.php
2015-10-05 08:17:07.618 ..... SCRIPT .... XXX.XXX.XXX.XXX    ->/tool/jsonQuery.php
2015-10-05 08:17:08.043 ..... SCRIPT .... XXX.XXX.XXX.XXX /view/objectDetail.php
2015-10-05 08:17:08.044 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=objectDetail.php
2015-10-05 08:17:08.225 ..... SCRIPT .... XXX.XXX.XXX.XXX    ->/view/objectDetail.php
2015-10-05 08:17:09.436 ..... SCRIPT .... XXX.XXX.XXX.XXX /view/objectDetail.php
2015-10-05 08:17:09.437 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=objectDetail.php
2015-10-05 08:17:09.581 ..... SCRIPT .... XXX.XXX.XXX.XXX    ->/view/objectDetail.php
2015-10-05 08:17:09.655 ..... SCRIPT .... XXX.XXX.XXX.XXX drawTableFromObject(obj, included=, parentReadOnly=)
2015-10-05 08:17:10.156 ..... SCRIPT .... XXX.XXX.XXX.XXX drawTableFromObject(obj, included=1, parentReadOnly=)
2015-10-05 08:17:10.988 ..... SCRIPT .... XXX.XXX.XXX.XXX /tool/saveCollapsed.php
2015-10-05 08:17:10.989 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=saveCollapsed.php
2015-10-05 08:17:11.059 ..... SCRIPT .... XXX.XXX.XXX.XXX /tool/saveCollapsed.php
2015-10-05 08:17:11.059 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=saveCollapsed.php
2015-10-05 08:17:11.127 ..... SCRIPT .... XXX.XXX.XXX.XXX /tool/saveCollapsed.php
2015-10-05 08:17:11.128 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=saveCollapsed.php
2015-10-05 08:17:11.193 ..... SCRIPT .... XXX.XXX.XXX.XXX /tool/saveCollapsed.php
2015-10-05 08:17:11.194 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=saveCollapsed.php
2015-10-05 08:17:11.259 ..... SCRIPT .... XXX.XXX.XXX.XXX /tool/saveCollapsed.php
2015-10-05 08:17:11.260 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=saveCollapsed.php
2015-10-05 08:17:11.363 ..... SCRIPT .... XXX.XXX.XXX.XXX /tool/saveCollapsed.php
2015-10-05 08:17:11.364 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=saveCollapsed.php
2015-10-05 08:17:11.511 ..... SCRIPT .... XXX.XXX.XXX.XXX /tool/saveCollapsed.php
2015-10-05 08:17:11.512 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=saveCollapsed.php
2015-10-05 08:17:11.577 ..... SCRIPT .... XXX.XXX.XXX.XXX /tool/saveCollapsed.php
2015-10-05 08:17:11.577 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=saveCollapsed.php
2015-10-05 08:17:11.642 ..... SCRIPT .... XXX.XXX.XXX.XXX /tool/saveCollapsed.php
2015-10-05 08:17:11.643 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=saveCollapsed.php
2015-10-05 08:17:27.715 ..... SCRIPT .... XXX.XXX.XXX.XXX Page=checkAlertToDisplay.php
05 Oct 2015 09:08 #4 by babynus
No hint in the log file. :(
Could you check structure of the table "planningelement" in the database ?
It should be something like this (check format of validatedWork field) :
05 Oct 2015 09:34 #5 by fdoucet
this is the table structure, it's the same type
05 Oct 2015 09:36 #6 by babynus
Yes, structure is correct and so cannot explain issue.
Do yo reproduce only on validatedWork or also on other numeric fields ? (for instance validatedCost)
