ProjeQtOr free project management software - ValidatedWork reset - Page 3 - ProjeQtOr
ValidatedWork reset
05 Oct 2015 14:00 #13 by fdoucet
Replied by fdoucet on topic ValidatedWork reset
i just try in new instance with db empty.
the problem is also with other field, if you see the attachement assignated or rest work is not display in the array
05 Oct 2015 14:21 #14 by babynus
Replied by babynus on topic ValidatedWork reset
Do you mean previous attachment ?
(no new attachement found)
Ther seem to be no assigned work, so zero value can be good result ;)
(I guess ther is no assigned because on screenshit with 2 days validated, there is still no assigned)
Did you add assigned work ?
Can you try with ne decimal ?
Is assigned and left correct ?
NB : thry and clean browser cache to avoir any js issue...
Could you then check browser console for any issue ?
05 Oct 2015 14:42 #15 by fdoucet
yes it's the previous screenshot
if i change the value for a non decimal number the assigned value it's good.
i have no message in the console
i have clean the browser
06 Oct 2015 09:35 #16 by babynus
What is your visual deciaml character ?
Is it point '.' or comma ',' ?
06 Oct 2015 09:41 #17 by fdoucet
hi,
the decimal character is comma
06 Oct 2015 09:55 #18 by babynus
It is must be a decimal translation issue on display.
Problem is that it is done by dojo, and it makes it correctly in most cases, bot not in yours.
Could you give more hints about configuration :
Client : OS, version of OS, browser, version of browser, locale
Server : OS, version of OS, 32 or 64 bit, virtualized or not
Any information may help
