ProjeQtOr free project management software - Problems with lists of objects - ProjeQtOr
19 Jun 2014 15:57 - 19 Jun 2014 17:49 #1 by Jean-Luc
I found two problems when working on Projeqtor.
1. In lists of objects (p.e. Users), translatable data appears only with internal value ([profileAdministrator]) instead of the translated value ('administrateur').
Not very sexy…
2. When any changes are made in a module for display, there is conflicts between new values or data in the module and recording in 'columnselector' values.
To avoid wrong display, I delete all lines for the concerned entities, so a new recording is done with good data and values (long life to PhpMyAdmin ! ;)
But it seems that something has not been provided for clean structural changes…
Last edit: 19 Jun 2014 17:49 by Jean-Luc.
20 Jun 2014 09:21 #2 by babynus
Not very sexy…
It is because "profileAdministrator" is not included in lang.js file.
Yes, there is :woohoo:
In the fields selector list, click the "reset" button.
20 Jun 2014 11:41 #3 by Jean-Luc
Not very sexy…
No, all values ARE in lang.js files. They comes right in the detail section when an element is selected.
The problem is only in the objects list (top part of the screen)
Where is that “fields selector list”? Not found on any screen, nor in the documentation…
21 Jun 2014 10:29 #4 by babynus
They are translated : exemple, profile in user list is correctly translated.
You muist just correctly define format in $_layout :
<th field="nameProfile" width="15%" formatter="translateFormatter">${idProfile}</th>
Here :
21 Jun 2014 10:56 #5 by Jean-Luc
But this has only for effect that "profileAdministrator" is replaced by "[profileAdministrator]", not by the language-translated value.
And what for fields having already a formatting, as colorNameFormatter ?
Here :
Ah, O.K. Thanks !
I’ll go to bed less dumb, this evening. :P
21 Jun 2014 11:14 #6 by babynus
This is because [profileAdministrator] is not found in lang.js file by the javascript code
So you'll need to clean the browser cache to get the translation. Some times, cleaning the cache is not enough, and you may need to close the browser.
I sometimes had difficulties to retrieve the correct translations on javascript side.
Also concider cleaning "server side" cache.
