ProjeQtOr free project management software - Problems with lists of objects - Page 2 - ProjeQtOr
21 Jun 2014 11:58 #7 by Jean-Luc
Sorry, don’t work, whatever I did (emptying cache, exit from Browser, and until shutdown/restart the computer – I work with local server, so all caches are empty).
Display still looks like this :
However, what for fields having already a formatting, as colorNameFormatter ?
21 Jun 2014 12:28 #8 by babynus
1) all the countryXxxx must exit in the translation file.
2) the layout must be :
<th field="name" width="15%" formatter="translateFormatter">${name}</th>
You cannot have simultaneously colorNameFormatter and translateFormatter (one only)
21 Jun 2014 13:02 #9 by Jean-Luc
babynus wrote: 1) all the countryXxxx must exit in the translation file.
But IT IS the layout !!! (only width is different, but pure html parameter).
Whatever I can do, the translation at this level only put the name between brackets – as it was not in lang.js…
babynus wrote: You cannot have simultaneously colorNameFormatter and translateFormatter (one only)
Too bad.
Thus I have to create a "colorTranslateNameFormatter" (found the module containing these functions. ;) )
(possible enhancement for a future version, no ?)
21 Jun 2014 13:30 #10 by babynus
You have to reset layout (as shown on previous screenshot) to take into account layout change.
Possible.
But I will not spend time on this, as I pesonnaly see no interest to it.
If you code it, please post it so that include change in later version.
21 Jun 2014 13:40 #11 by Jean-Luc
It put a track in the i18n function for values not found.
Correct for some other missing values as "AuditSummary", "mandatory", "indicatordefinitionActualDueDateTime", "indicatordefinitionInitialDueDateTime" or "tickettypeTypeTicketIncident"…
But nothing about expected translations. So :
1. i18n is not called (or called with $i18nMessages set).
2. Implies translateFormatter is not called or with an empty value.
But in second case, from where come the brackets ? So I think $i18nmessages wrongly set.
I continue investigation…
21 Jun 2014 14:47 - 22 Jun 2014 09:35 #12 by Jean-Luc
Problem localized:
When calling function i18n in projeqtor.js, even when i18nMessages loaded, the string to translate is never found!
… but as I’m not fluent with javascript, I am not able to see deeper…
(I don’t know how to display javascript array content)
Edit 22 june : suceeded to return length of array i18nMessages : always "undefined", so no values are returned by function "dojo.i18n.getLocalization".
Can you investigate with these infos?
Last edit: 22 Jun 2014 09:35 by Jean-Luc.
