ProjeQtOr free project management software - Problems with lists of objects - Page 4 - ProjeQtOr
23 Jun 2014 14:15 #19 by Jean-Luc
babynus wrote:
Thus I have to create a "colorTranslateNameFormatter" (found the module containing these functions. ;) )
(possible enhancement for a future version, no ?)
Possible.
But I will not spend time on this, as I pesonnaly see no interest to it.
If you code it, please post it so that include change in later version.
Done, very easy.
Just:
1. duplicate colorNameFormatter in view/js/projeqtorFormatter.js et tool/formatter.php, renaming the copy as colorTranslateNameFormatter;
2. in tool/formatter.php, replace in "return" line with html code "$val" by "i18n($val)";
3. in view/js/projeqtorFormatter.js, replace in "return" line with html code "val" by "i18n(val)".
Now, you can replace in various models «formatter="colorNameFormatter"» with «formatter="colorTranslateNameFormatter"» in translatable colored fields.
It works perfectly. :P
23 Jun 2014 14:21 #20 by babynus
