ProjeQtOr free project management software - [SOLVED] TODAY Screen issues - ProjeQtOr
23 Jul 2013 08:51 - 15 Apr 2014 11:41 #1 by Iaurkano
i babynus,
i tried 3.3.2 before migration and i met a strange behaviour :
in today screen if à had a report à don't see the report but the waiting cursor.
If à print the today page in the print preview i see the report.
another thing :
when i click on today paraméters icons in the configuration windows i see this :
Strange name "unknown today scope"
i left the page and if i click once again on the parameter icon new "unknow today scope" element appears. like this :
i work on IE8 on Windows XP my server is in Windows server 2003.
thank's
Last edit: 15 Apr 2014 11:41 by Iaurkano. Reason: Solved
23 Jul 2013 09:17 #2 by climb4fun
Hi Iaurkano,
I had this issue some weeks ago as well. I remove this "unknown today scope" and then I was fine again. In my case it was due to migration tests backward and forward.
Hope this helps,
Klaus
23 Jul 2013 10:06 - 23 Jul 2013 10:07 #3 by Iaurkano
my problems is, i can't remove these. Each time i open the configuration screen these items re-appears.
if i open the configuration twice, i see 2 times more "unknown today scope" items, if third i see 3 times more "unknown today scope".
Very strange behaviour.
thank's
Last edit: 23 Jul 2013 10:07 by Iaurkano.
23 Jul 2013 12:47 #4 by babynus
Replied by babynus on topic 3.3.2 - TODAY Screen issues
Try this fix :
in /model/Today.php
replace function insertStaticItems() with this one :
public static function insertStaticItems() {
  	$user=$_SESSION['user'];
  	$sort=0;
  	foreach (self::$staticList as $static) {
  		$crit=array('idUser'=>$user->id, 'scope'=>'static', 'staticSection'=>$static);
  		$sort+=1;
  		$item=SqlElement::getSingleSqlElementFromCriteria('Today', $crit);
  		if (!$item->id) {
  			$item->sortOrder=$sort;
  			$item->idle=0;
  			$item->scope='static';
  			$item->save();
(one line added)
You should also clear all lines in table Today for which scope is not 'static' or 'report'.
23 Jul 2013 13:29 #5 by Iaurkano
ok i will try this and i'll keep you informed.
regards?
31 Jul 2013 15:02 #6 by Iaurkano
Hi babynus,
Your fix does not correct my issue.
in the DATABASE i have only records where field scope is 'static'.
regards.
