ProjeQtOr free project management software - [SOLVED] TODAY Screen issues - Page 2 - ProjeQtOr
31 Jul 2013 17:44 #7 by babynus
Replied by babynus on topic 3.3.2 - TODAY Screen issues
You should try V3.4.1
01 Apr 2014 17:05 - 01 Apr 2014 17:25 #8 by Iaurkano
hi,
i had this issue in my previous 3.4.4 version, and with the new 4.2.2 version too.
here after the todays configuration screen.....
One more things i had these three tables in the the database :
today
todayParameter
and
todayparameter
is it normal ?
regards
Last edit: 01 Apr 2014 17:25 by Iaurkano. Reason: correction
01 Apr 2014 17:38 - 01 Apr 2014 17:38 #9 by babynus
You should
- remove todayParameter
- empty todayparameter
Your issue may be due to running setup/upgrade several times.
Last edit: 01 Apr 2014 17:38 by babynus.
03 Apr 2014 08:37 #10 by Iaurkano
all was done, but the problem still present.
one idea babynus ??
08 Apr 2014 08:27 #11 by climb4fun
Replied by climb4fun on topic TODAY Screen issues
Hi Iaurkano,
maybe you can look into table "today", whether there are double entries for your user.
Klaus
The following user(s) said Thank You: Iaurkano
14 Apr 2014 16:08 - 14 Apr 2014 16:09 #12 by Iaurkano
Replied by Iaurkano on topic TODAY Screen issues
Ok,
So in fact, each time i open the "today configuration screen" 5 records are added in the today table, here below an extract of the today table (now there are 105 records for my user) :
the added records have the field "static section" set to NULL, like the last records below.
ididUserscopestaticSectionidReportsortOrderidle
11staticProjects(NULL)11
201staticAssignedTasks(NULL)21
391staticResponsibleTasks(NULL)31
581staticIssuerRequestorTasks(NULL)41
771staticProjectsTasks(NULL)51
961staticProjects(NULL)11
1141staticAssignedTasks(NULL)21
1321staticResponsibleTasks(NULL)31
1501staticIssuerRequestorTasks(NULL)41
1681staticProjectsTasks(NULL)51
1861static(NULL)(NULL)11
1871static(NULL)(NULL)21
1881static(NULL)(NULL)31
1891static(NULL)(NULL)41
1901static(NULL)(NULL)51
1911static(NULL)(NULL)11
1921static(NULL)(NULL)21
1931static(NULL)(NULL)31
Last edit: 14 Apr 2014 16:09 by Iaurkano.
