ProjeQtOr free project management software - [SOLVED] TODAY Screen issues - Page 3 - ProjeQtOr
15 Apr 2014 08:48 #13 by climb4fun
Replied by climb4fun on topic TODAY Screen issues
Hi Iaurkano,
if you are familiar with SQL, then try to set one of your double entries "idle to 0". Then you should see, this item is out of today. If it works, then you can put all other duplicates to idle = 0 as well. Or you delete the records, but this is more risiky, because this could not be restored afterwards.
Anyhow, make a dump of your database before modifying anything.
Best regards,
Klaus
The following user(s) said Thank You: Iaurkano
15 Apr 2014 11:41 #14 by Iaurkano
Hi all,
after lot's of investigation, i found the solution.
so : In the table today, I deleted all records where scope ="static" and staticSection=NULL and all records in double.
after that, today screen works perfectly.
Thank's.
