ProjeQtOr free project management software - Importation doesn't work - ProjeQtOr
28 Nov 2012 13:00 - 28 Nov 2012 14:45 #1 by jmmbb
I'm trying to import PROJECTS into PROJECTOR (V 3.0) for preparing annual work plan for 2013.
For test, i'm using a CSV file as attached.
When i'm using IMPORT DATA function in PROJECTOR, there is no message, and nothing is imported. :(
Log is attached to...
Thanks !
Last edit: 28 Nov 2012 14:45 by jmmbb.
28 Nov 2012 14:25 - 28 Nov 2012 14:26 #2 by babynus
I cannot find attached log.
Could you also attach or send me CSV file (or at least extract of it) ?
Last edit: 28 Nov 2012 14:26 by babynus.
28 Nov 2012 14:45 #3 by jmmbb
Replied by jmmbb on topic Re: Importation doesn't work
Attachments updated (wrong file type)
28 Nov 2012 15:31 #4 by babynus
Your CSV file has 2 erroneous lines (line 2 and 3)
id;nom;type;MOA;CdP MOA;SI de rattachement;Numéro GSIM;est sous projet de;manager;couleur;état;fait;date de fin;clos;date de clôture;description;date de début initiale;date de début validée;date de début planifiée;date de début réelle;wbs;date de fin initiale;date de fin validée;date de fin planifiée;date de fin réelle;avancement;durée initiale;durée validée;durée planifiée;durée réelle;travail validé;travail assigné;travail planifié;travail réel;travail restant;coût validé;coût assigné;coût planifié;coût réel;coût restant
int(12);varchar(100);int(12);int(12);int(12);varchar(25);varchar(25);int(12);int(12);varchar(7);int(12);int(1);date;int(1);date;varchar(4000);date;date;date;date;varchar(100);date;date;date;date;int(3);int(5);int(5);int(5);int(5);decimal(14,5);decimal(14,5);decimal(14,5);decimal(14,5);decimal(14,5);decimal(11,2);decimal(11,2);decimal(11,2);decimal(11,2);decimal(11
28 Nov 2012 15:37 #5 by jmmbb
Oups ! :S
I need to sleep a little more...
By the way, even with to new file (as attached), there's no message and no import...
Thanks for reactivity !
28 Nov 2012 16:27 #6 by babynus
Even waiting for a while ?
You should have some problem to upload file.
Can you easily upload attached files (for instance on tickets) ?
