ProjeQtOr free project management software - Importation doesn't work - Page 2 - ProjeQtOr
28 Nov 2012 16:29 #7 by jmmbb
Replied by jmmbb on topic Re: Importation doesn't work
yes, it's works fine for attaching files, tickets, project, activity, every attachement is working.
28 Nov 2012 16:32 #8 by jmmbb
I do another test with same file, nothing append... only waiting wheel, just 1 second and nothing more...
28 Nov 2012 17:25 #9 by babynus
Very strange.
I tried on test database : all is working fine with your file :
(You have date format error, but not hard to fix ;) )
Check you have access to temporary directory :
../files/attach//import/
, with write access.
Check that file "Test import.csv" is present.
Try to remove space in file name.
If all this does not work, you'll have to debug :
in /model/Importable.php, in the function import(), add several lines :
echo "import - Step 1"
echo "import - Step 2"
Log show you enter correctly the import function :
import(../files/attach//import/Test import.csv, Project)
28 Nov 2012 17:41 - 28 Nov 2012 17:43 #10 by jmmbb
file is present in ../files/attach/import
After delete, i do a new import, files is present again (whitout space in filename) but doesn't work anymore.
Even with ECHO in import function, i can't get any result, here's the log :
2012-11-28 17:38:03 ..... SCRIPT .... XX.XXX.12.130 /tool/import.php
2012-11-28 17:38:03 ..... SCRIPT .... XX.XXX.12.130 ->/tool/import.php
Attachement is Importable.php after inserting ECHOS.
Last edit: 28 Nov 2012 17:43 by jmmbb.
28 Nov 2012 17:58 #11 by babynus
You previously had the first trace in the procedure in the log.
You don't have it anymore ?
2012-11-28 12:52:48 ..... SCRIPT .... 10.xxx /tool/import.php
2012-11-28 12:52:48 ..... SCRIPT .... 10.xxx    ->/tool/import.php
2012-11-28 12:52:48 ..... SCRIPT .... 10.xxx import(../files/attach//import/Test import.csv, Project)
Could you also add "echos" just at the begining of the procedure (step 0) ?
29 Nov 2012 09:00 #12 by jmmbb
New test this morning...
Function import will be executed until BeginTransaction
Log is :
2012-11-29 08:56:28 ===== TRACE ===== NEW CONNECTED USER 'bremont'
2012-11-29 08:56:28 ..... SCRIPT .... <serveur> /tool/saveDataToSession.php
2012-11-29 08:56:29 ..... SCRIPT .... <serveur> /tool/saveDataToSession.php
2012-11-29 08:56:29 ..... SCRIPT .... <serveur> /view/main.php
2012-11-29 08:56:29 ..... SCRIPT .... <serveur> ->/view/main.php
2012-11-29 08:56:29 ..... SCRIPT .... <serveur> ->/view/menuTree.php
2012-11-29 08:56:29 ..... SCRIPT .... <serveur> ->/view/menuBar.php
2012-11-29 08:56:32 ..... SCRIPT .... <serveur> /tool/saveDataToSession.php
2012-11-29 08:56:32 ..... SCRIPT .... <serveur> /tool/jsonDirectory.php
2012-11-29 08:56:32 ..... SCRIPT .... <serveur> ->/tool/jsonList.php
2012-11-29 08:56:32 ..... SCRIPT .... <serveur> /tool/cronRelaunch.php
2012-11-29 08:56:32 ..... SCRIPT .... <serveur> /view/today.php
2012-11-29 08:56:32 ..... SCRIPT .... <serveur> ->/view/today.php
2012-11-29 08:56:37 ..... SCRIPT .... <serveur> /view/importData.php
2012-11-29 08:56:37 ..... SCRIPT .... <serveur> ->/view/importFile.php
2012-11-29 08:56:55 ..... SCRIPT .... <serveur> /tool/import.php
2012-11-29 08:56:55 ..... SCRIPT .... <serveur> ->/tool/import.php
2012-11-29 08:56:55 ..... SCRIPT .... <serveur> import(../files/attach//import/Testimport.csv, Project)
