ProjeQtOr free project management software - Importation doesn't work - Page 3 - ProjeQtOr
29 Nov 2012 15:52 #13 by babynus
Very strange. :huh:
Can you try to comment the transaction lines :
Sql::beginTransaction();
and
Sql::commitTransaction();
in this function to see how it goes ?
29 Nov 2012 18:16 #14 by jmmbb
Replied by jmmbb on topic Re: Importation doesn't work
It done, here is the result :
Import - Step 1 : initImport - Step 2 - Class existImport - Step 3 - Sql::beginTransaction()
Function stop before CommitTransaction...
Here is the log :
2012-11-29 18:13:53 ..... SCRIPT .... <Serveur> /tool/import.php
2012-11-29 18:13:53 ..... SCRIPT .... <Serveur> ->/tool/import.php
2012-11-29 18:13:53 ..... SCRIPT .... <Serveur> import(../files/attach//import/Testimport.csv, Project)
02 Dec 2012 13:16 - 02 Dec 2012 13:19 #15 by babynus
I really don't understand why you can't get it work.
I tried on :
- windows / mysql : OK
- linux (debian) / mysql : OK
- linux (debian) / postgresql : OK
Could you precise your test environment :
- php server OS / version
- php version
- db server OS / version
- db used (mysql/postgres) and version
Also, could you also test with joined Importable.php file ?
I added many debug line to track progress of treatment.
For information, I joined the log file that was geznerated with this debug level, with correct treatment of your test file.
Last edit: 02 Dec 2012 13:19 by babynus.
03 Dec 2012 12:00 #16 by jmmbb
PHP : 5.2.3
MySQL : 5.0.77
I'll tried with new version of IMPORTABLE.PHP, log is attached...
Thanks !
03 Dec 2012 14:36 - 03 Dec 2012 14:47 #17 by babynus
The issue is on these lines :
if (trim($line)=='') {
				continue;
			if (! mb_detect_encoding($line, 'UTF-8', true) ) {
				$line=utf8_encode($line);
Can you check mbstring plugin on you php ?
(run joined info.php file)
You should get something like this :
Last edit: 03 Dec 2012 14:47 by babynus.
03 Dec 2012 16:01 #18 by jmmbb
Ok, that's the reason.
After enabling mbstring plugin, it works !
Many thanks !
