ProjeQtOr free project management software - Problem on updating Projeqtor (rollback needed) - ProjeQtOr
04 Jun 2021 09:08 #1 by Cpt_Jabberwock
For some reason, we have a problem on our Projeqtor since 9.1.3
We have done absolutely nothing in changing anything file related, or something that would pose problem (in our eyes)
But when i tried to update to 9.1.4 (and today, to 9.1.5, because waiting for next update just in case can help), i get the login screen after update like usual, but when i lo with my administrator account to initialise and open the app, i get this:
Do you have any idea what could cause this ?
Are there specific logs we should look into ?
Thank you
04 Jun 2021 14:46 #2 by babynus
Please look at the error log.
You'll have explanation (possibly an access right error)
If you don't understand the error, post it here.
07 Jun 2021 09:48 #3 by Cpt_Jabberwock
I don't quite understand where exactly is the specific log needed on the apache server, but this is what I found for June 4th when i updated it
File Attachment:
File Name: syslog.3.txt
File Size:33 KB
If this is not this one, which one should it be ?
Thank you
12 Jun 2021 17:34 #4 by babynus
Error will be in projeqtor log file.
Defaut location is in projeqtor/file/logs
14 Jun 2021 09:43 #5 by Cpt_Jabberwock
Thank you,
After finding it and doing a test on another Vm we made just for this, which was in 8.3.3
I updated it to 9.0.6 without any problem
Then, when i tried to update to 9.1.5, i encountered the same problem i talked about above
I then made sure it was this log by trying to connect and looking at the modification date
File Attachment:
File Name: projeqtor_...0614.log
File Size:164 KB
Thank you
15 Jun 2021 11:29 #6 by babynus
You log file show migration from V8.3.4 to V9.0.6, which ran without issue.
The you have error
2021-06-14 09:32:15.642 ***** ERROR ***** [V9.0.6] cause = ldap_connect(): Could not create session handle: Bad parameter to an ldap routine
It seems your PHP does not undestand new URI format for LDAP connection.
Which version of PHP are you using ?
NB : to fix the issue, just change 1356 in projeqtor/model/UserMain.php from
              if (1) { // New signature
to
              if (0) { // New signature
We searched for compatibility of new signature depending on PHP version but did not find the information.
Please tell us which version of PHP you are using so that we may improve the code.
The following user(s) said Thank You: Cpt_Jabberwock
