ProjeQtOr free project management software - Problem on updating Projeqtor (rollback needed) - Page 3 - ProjeQtOr
08 Sep 2021 15:37 #13 by Cpt_Jabberwock
There was no change on our side.
we rewrote the password on top on the old in authentification in Global Parameters, but the result stay the same
13 Sep 2021 00:44 #14 by bvd
You have to write the line in parameters.php with single quote, like this :
$ldapFormatUri='false';
Writing line without single quotes simply won't work.
04 Oct 2021 14:12 #15 by Cpt_Jabberwock
Hello again,
So, i opened Parameter.php and i have thousands of lines to sift thru to know where to put $ldapFormatUri='false';
Could you pinpoint me what section is should look for ?
Thank you
04 Oct 2021 14:41 #16 by babynus
You don't have to change model/Parameter.php file which is part of community code and will be overwrfitten at each migration
You need to change you parametering file, that is stored at setup and never overwritten.
Default location is files/config/parameters.php, but may be (and should be for security reason) changed at setup.
You'll find location in tool/parametersLocation.php
04 Oct 2021 14:54 #17 by Cpt_Jabberwock
This is perfect
Thanks :D
