ProjeQtOr free project management software - Problem on updating Projeqtor (rollback needed) - Page 2 - ProjeQtOr
28 Jun 2021 10:52 - 28 Jun 2021 10:54 #7 by Cpt_Jabberwock
Thank you, it worked
Apparently, this line is added after applying the update (from 9.1.4 i suppose) so we need to change it after we get blocked in trying to connect again after
Changing it worked as advertised
The PHP version we use is 7.0.30
Last edit: 28 Jun 2021 10:54 by Cpt_Jabberwock.
28 Jun 2021 15:30 #8 by babynus
In V9.2.1 you'll be able to add parameter in your prameters.php file
$ldapFormatUri=false;
so that LDAP will work fine for you whatever the migration.
02 Sep 2021 11:46 #9 by Cpt_Jabberwock
A new problem occured but this time, from 9.1.5 to 9.2.2
File Attachment:
File Name: projeqtor_...0901.log
File Size:2 KB
We have looked into what we did the last time, but the error seems different.µ
Could you look into this please ?
07 Sep 2021 11:03 #10 by babynus
LDAP password is encrypted on V9.2, so migration requires a connection with non-ldap admin user.
07 Sep 2021 11:53 #11 by Cpt_Jabberwock
Hello again and thanks for the reply
It worked after logging with Admin
After opening the application back to other users, i tried to log back with my account, but encountered an error.
It may be due to the parameter for parameters.php posted above not having been done, but i'm not sure yet.
I will look into it, but can you tell me regardless if you have an idea ?
Thank you
07 Sep 2021 14:22 #12 by babynus
Reconnext as Admin and update LDAP password in global parameters.
