ProjeQtOr free project management software - Field customization - Page 2 - ProjeQtOr
Field customization
08 Feb 2019 11:45 #7 by babynus
Replied by babynus on topic Field customization
You showed print for ticket #48.
Try and change it, anything will do (possible just save without any change will do the job, but I'm not sure)
08 Feb 2019 13:03 #8 by lsigroup
Replied by lsigroup on topic Field customization
Effectively, i just saved without any change and it works. why do i have to do that unitarily ? is there any solution?
08 Feb 2019 15:44 #9 by babynus
Because default value is applied on saving...
Make a minor change (for instance add a space on description) with multiple update feature
The following user(s) said Thank You: lsigroup
