ProjeQtOr free project management software - Field customization - ProjeQtOr
Field customization
06 Feb 2019 12:34 #1 by lsigroup
Field customization was created by lsigroup
Hi
Several points
1. Is it possible to rename menu such as "ticket" for example? (i have bought customization field plugin)
2. i would like to put a default value on a reference field but it seems that it does not work. How to proceed ?
3. i would like to display customer on a ticket, retrieved automatically from the concerned project, but it does not work, only a drop down list is available with all customers. How to proceed please ? Same thing that happen in QUOTE screen in reality... Or would it be possible to have a field "customer" displaying the customer from the requester?
06 Feb 2019 16:40 - 06 Feb 2019 16:40 #2 by babynus
Replied by babynus on topic Field customization
Not with screen custo.
This is possible with "personalized translations"
Default value is evaluated only on creation.
If you need a "calculated" field, set the field as readlony additionnaly to default value.
Possibly you can manage with default value...
- set field as readonly
- entrer default value as
###EVAL###(new Project($this->idProject))->idClient
Last edit: 06 Feb 2019 16:40 by babynus.
07 Feb 2019 23:30 - 07 Feb 2019 23:30 #3 by lsigroup
Replied by lsigroup on topic Field customization
for point 3 i did what you told me but it does not work. Please see file attached
Last edit: 07 Feb 2019 23:30 by lsigroup.
07 Feb 2019 23:31 #4 by lsigroup
With files attached
08 Feb 2019 09:59 #5 by babynus
You mlust make some change on the item.
The default value won't be automatically applied to all existing items.
08 Feb 2019 10:43 #6 by lsigroup
I'm sorry but i do not understand your reply. Which changes ? Which Item?
