ProjeQtOr free project management software - Fields management - ProjeQtOr
Fields management
01 Feb 2019 20:41 #1 by lsigroup
Fields management was created by lsigroup
Hi
Is It possible to remove field from a screen because useless ? Or maybe to rename It ?
02 Feb 2019 00:56 #2 by babynus
Replied by babynus on topic Fields management
lsigroup wrote: Hi
It is possible with screen customization plugin
05 Feb 2019 10:00 #3 by lsigroup
Replied by lsigroup on topic Fields management
Hi i bought screen customization plug-in. is it normal that most of the field name cannot be updated (field is greyed in the plug in) ?
05 Feb 2019 10:02 #4 by lsigroup
Moreover, is it possible to rename menu such as "ticket" for example?
05 Feb 2019 10:35 #5 by lsigroup
Another question : i would like to put a default value on a reference field but it seems that it does not work. How to proceed ?
05 Feb 2019 11:42 #6 by lsigroup
another question :)
How to make a list I created, depending on the existing product list ? I want to make a link between module & product
