ProjeQtOr free project management software - Fields management - Page 3 - ProjeQtOr
Fields management
06 Feb 2019 18:19 #13 by lsigroup
Replied by lsigroup on topic Fields management
babynus wrote:
Another question : i would like to put a default value on a reference field but it seems that it does not work. How to proceed ?
Have a look at user manual of plugin.
Take care "default" value is managed only on creation.
It is not a calculated value, unless you set the field as readonly
I'm sorry but not a developper. Even when reading the user manual i do not catch what to do. How to set one value as default, for example the first one?
08 Feb 2019 09:27 #14 by babynus
Replied by babynus on topic Fields management
To define a fixed default value, just enter the value : "1" for instance.
To calculate the defaut value, use "###EVAL##xxxx" where xxx is some php code returning the expected value. But sure, you'll need a few ph knowledge to use this.
08 Feb 2019 12:58 #15 by lsigroup
I'm sorry to say that if i put 1 or 2 for example, value by default is still the same (the figure is the ID of the item, you confirm?)
08 Feb 2019 15:32 #16 by babynus
Please show your config and be sure to make changes on item.
I insist : defining default value will not automatically update exisitng items. This will be taken into account only for new items (or when updating item)
14 Feb 2019 11:31 #17 by lsigroup
Hi
in fact, at ticket creation, the field is not visible (workflow rule). When the field becomes visible, the default value is not the one i "forced" in the customization plugin. Please clarify.
14 Feb 2019 16:59 #18 by babynus
Default value won't work for hidden fields.
The following user(s) said Thank You: lsigroup
