ProjeQtOr free project management software - Problem with Full time equivalent (ETP in french) - ProjeQtOr
17 Dec 2018 11:27 #1 by Bena
On my ressource profile, I have an ETP set to 1. When I compute the planning, projeqtor does not assign me 1 day of work. It's usually between 0.58 and 0.6 day.
So I tried to reduce my ETP. And when I set it below 0.4, I have the following error :
2018-12-17 11:14:23.162 ***** ERROR ***** [V7.2.7] ERROR *****
2018-12-17 11:14:23.163 ***** ERROR ***** [V7.2.7] on file '/projeqtor/projeqtor/model/ProjectMain.php' at line (647)
2018-12-17 11:14:23.163 ***** ERROR ***** [V7.2.7] cause = Creating default object from empty value
Can you help me ?
Bena
17 Dec 2018 14:42 #2 by babynus
Can you show print screen of what you do ?
It's not clear as you deal with resource capacity and point out error on project...
17 Dec 2018 15:07 #3 by Bena
Sorry, i forget one step.
The error is displayed when I calculate all project from the gantt planning.
Bena
17 Dec 2018 17:40 #4 by babynus
I really don't think is is linked to FTE of resource...
... but who really knows, except God
... and even God may not be sure when subject is computer programming.
But I cannot reproduce.
Could you try and reproduce on Demo ?
Could you also check for consistency issues (check is avaialble on admin screen)
18 Dec 2018 14:18 #5 by Bena
No error with the consistency check.
I've try with an other ressource on the same instance of projeqtor and there is no error.
I've just the error with me (as ressource). An other strange thing, Projeqtor never allow me to work more than 0.6 day a day (with a FTE of 1).
The only way for me to have 1 day of work planned each day is to set my FTP to 1.4.
It's like that somewhere on the app, 0.4 is remove from my FTE. So if I set my FTE under 0.4, my true FTE is under 0 and the calculation of the planning crash.
Bena
19 Dec 2018 21:05 #6 by babynus
Can you check with report "Color Monthly Reource planning" if your resource is used on another project ?
