ProjeQtOr free project management software - Problem with Full time equivalent (ETP in french) - Page 2 - ProjeQtOr
20 Dec 2018 18:06 #7 by babynus
I think you have some unconsistency in data, that is not displayed but generates issues.
We have completed consistency checks on V7.3, and fixed an issue on the subjet on V7.3.2 (that will soon be deployed).
I hope that consistence checks on V7.3.2 will fix your issue.
21 Dec 2018 09:52 #8 by babynus
I think I've found your planning issue.
It does not come from FTE, but from use of global planning.
This issue should be fixed on V7.3.2
You FTE issue comes (almost sure) from a project "using" part of your availability.
Possibly a fixed project.
Check in reports for planned work.
The following user(s) said Thank You: Bena
04 Jan 2019 10:12 #9 by Bena
I've just installed the version 7.3.3. It's better. Instead of loosing 0.4 day by day (with a FTE at 1), I juste loose 0.21 day.
When I set my FTE to 0.1 and try to calculate the planning I have the following error :
2019-01-03 18:33:28.489 ***** ERROR ***** [V7.3.3] ERROR *****
2019-01-03 18:33:28.489 ***** ERROR ***** [V7.3.3] on file '/projeqtor/projeqtor/model/ProjectMain.php' at line (647)
2019-01-03 18:33:28.489 ***** ERROR ***** [V7.3.3] cause = Creating default object from empty value
PS : I have run the check consistency in the admin part and it correct many error but I still have only 0.79 day planned each day.
Regards.
Bena
04 Jan 2019 20:24 #10 by babynus
Try and add one line before line 647 in /model/ProjectMain.php, like this
    debugLog($this);
    $this->ProjectPlanningElement->refName=$this->name;
Run the calculation that generates the error.
Then poste here log file.
07 Jan 2019 10:16 - 07 Jan 2019 10:22 #11 by Bena
The log is joined.
File Attachment:
File Name: projeqtor.log
File Size:5 KB
Bena
Last edit: 07 Jan 2019 10:22 by Bena.
07 Jan 2019 10:30 #12 by babynus
Try and change line 996 in model/ProjectMain.php from
$proj=SqlElement::getSingleSqlElementFromCriteria("ProjectPlanningElement",array('refType'=>'Project','refId'=>$id),true);
to
$proj=SqlElement::getSingleSqlElementFromCriteria("ProjectPlanningElement",array('refType'=>'Project','refId'=>$id),false);
Does it fix the issue ?
