ProjeQtOr free project management software - [SOLVED] Global Parameters: changes in Mailing Parameters are not stored - Page 2 - ProjeQtOr
26 Jun 2018 14:30 #7 by babynus
You msut not set value in partameters.php to empty string or null.
You must REMOVE the parameter (for instance comment the line)
26 Jun 2018 16:01 #8 by NorbertD
Thats the solution. If the Parameters are commented, then the Program use the Parameters in the form
thanks
