ProjeQtOr free project management software - [SOLVED] Global Parameters: changes in Mailing Parameters are not stored - ProjeQtOr
22 Jun 2018 13:29 #1 by NorbertD
i have installed Version 7.1.1 with PHPMAiler 6.0.3.
the Parameters which i change in the form Mailing parameters are not stored. after leaving the form and if i come back the Default is back.
also after i Input the new Parameters (esp. my SMTP Server) test mail give back "SMTP Connect failed" but i can Telnet port 25 our SMPT Server from this machine
thank you for your help
greetings
Norbert
26 Jun 2018 09:39 #2 by babynus
Please always install latest patch (current is V7.1.2)
Check if these parameters exist in the parameters.php file : values is not file overwrite any other stored value.
Telnet is not SMTP : SMTP connection may be refused for many reason :
- SMTP server requires SSL or TLS : so port will not be 25
- SMTP server required authentication
- SMTP server has blacklisted your IP
26 Jun 2018 10:08 #3 by NorbertD
thanks for your prompt answer.
your Solutions:
are (in my opinion) not possible. Because all the issues i have discussed with our SMTP Admin.
also everything worked fine with Version 6.x
So i think the Problem is that the Parameters are not stored. in the file Parameters.php. The Parameter $paramMailSmtpServer = 'localhost'
should i Change this in the config file?
is this problem solved in the new Version?
greetings
Norbert
26 Jun 2018 10:30 #4 by NorbertD
hello
i have changed the Parameter in the file Parameters.php and now it works.
maybe the Problem of not storing the changes in the form is, that i have changed file Location (outside of the projeqtor Installation)
greetings
Norbert
26 Jun 2018 10:58 - 26 Jun 2018 10:59 #5 by babynus
NorbertD wrote: hello
greetings
Norbert
rather than changing value in parameters.php, remove it : then value in global parameters is taken into account
Last edit: 26 Jun 2018 10:59 by babynus.
26 Jun 2018 11:28 #6 by NorbertD
that doesnt work because the program doesnt store the Parameter and use the value from Parameters.php.
so if the Parameter is empty the error message is SMTP Server is manadatory.
