ProjeQtOr free project management software - Project allocation - Page 4 - ProjeQtOr
Project allocation
19 Jun 2018 15:41 #19 by babynus
Replied by babynus on topic Project allocation
So you have hosted server.
You must request your hosting provider for logs or search on your control panel.
26 Jun 2018 09:16 #20 by bonga
Replied by bonga on topic Project allocation
I would like to know if two or more people can share a calendar on Projeqtor ?
26 Jun 2018 10:01 #21 by alainforma
Replied by alainforma on topic Project allocation
yes it is possible,
you have to go to Specific access, access to resource data, acces on diary.
then you have just to choose depending on each profil.
26 Jun 2018 11:14 #22 by bonga
Where do you find specific access ?
26 Jun 2018 11:39 #23 by alainforma
In the left menu area of the screen, key icon, then select it
26 Jun 2018 14:52 - 26 Jun 2018 14:53 #24 by alainforma
A simple clarification: I answered you about sharing the agenda.
If your question was about a calendar, you can choose a common calendar mode for each resource on screen "resource" at line "standard calendar" as dedicated.
If you want to modify it or create a new one go into the "environmental parameters" on menu and at the end of the list, select " standard calendar" .
Last edit: 26 Jun 2018 14:53 by alainforma.
