ProjeQtOr free project management software - Project allocation - Page 3 - ProjeQtOr
Project allocation
15 Jun 2018 16:00 #13 by babynus
Replied by babynus on topic Project allocation
All depends on your OS.
On Linux/debian you should find it at /var/logs/apache/errors.log
18 Jun 2018 10:19 #14 by bonga
Replied by bonga on topic Project allocation
I am using Windows 10 64bits OS, where can i find it on this OS?
18 Jun 2018 10:24 #15 by babynus
You must have installed a WAMP stack (WAMP Server or Easy PHP or else).
Open the console of this tool and search for Apache logs.
For instance on WAMP Server :
- click on WAMP icon on task bar
- move mouse over "Apache" line (a sub-menu opens)
- select "Apache error log"
19 Jun 2018 14:30 - 19 Jun 2018 14:32 #16 by bonga
After i have installed the WampServer will the error be solved and be able to create a new project since the functions are frozen at the moment ?
Last edit: 19 Jun 2018 14:32 by bonga.
19 Jun 2018 15:02 #17 by babynus
No, I don't talked abot you have to do, but what you must already have done.
ProjeQtOr is a web application, so you need a web server and db server (that's what Wamp does)
Please explain how you installed your Projeqtor...
19 Jun 2018 15:23 - 19 Jun 2018 15:23 #18 by bonga
We have a domain that we use to access the control panel from there i was able to install Projeqtor
Last edit: 19 Jun 2018 15:23 by bonga.
