ProjeQtOr free project management software - Big problem with ressource assigned to project - ProjeQtOr
20 Mar 2017 16:17 - 20 Mar 2017 16:29 #1 by dnaton
I have today a big problem with ressources assigned to project
When I assigned a ressource to a project, ProjeQtor do that
The name of the ressource but also the workload assigned don't appear :-(....and appear twice :huh:
And if I want to delete one theses entry, I can't
More problematic
  • All the assignements already entered don't work anymore :unsure:
  • I don't see it in an activity, meeting,...
  • and i I go to the screen "Imputation" to input real work to a ressource, there is nothing more. All my users don't have the task assigned and can't imput real workload
Where should I look first to check what' happend ?
thanks
Damien
Last edit: 20 Mar 2017 16:29 by dnaton.
22 Mar 2017 09:24 #2 by dnaton
I keep looking for where the problem comes from and I've some questions
The problem seems to come from id thas are not unique in some table.
What I don't understand is why now ?
I've got a question :
  • Should all tables have the value 'AUTO_INCREMENT" ?
I have some table with this value, some other without.
And If I look for a new install of Projeqtor, there are table with and table without.
And in one of my test environnement, all the table have this value.
So, I don't really understand :(
Is it a stupidity if I "force" this value AUTO_INCREMENT to all tables ?
Damien
22 Mar 2017 19:50 #3 by babynus
Yes.
id for all columns should be 'AUTO_INCREMENT"
This is not normal. All should have AUTO_INCREMENT on id.
I just tried new install, and can confirm that all tables are correct, with AUTO_INCREMENT on id.
This seem to be a solution.
But you must also identify why you get tables without AUTO_INCREMENT.
Maybe version of MySql ?
Or specific configuration ?
23 Mar 2017 09:39 #4 by dnaton
Effectively, all tables coming from a newx install have AUTO_INCREMENT on the "id" field.
I have an environnement that I considered like new install but I have certainly make some things that altered the tables....but why ? I don't know for the moment.
I'm doing tests in a test environnment to understand what happend, how and in which circumstances.
Anyway, I resolved my proble on my production environment :
  • Dump from my production database (only data) and structure in an other dump
  • Edit the dump to find and supress all the id=0 (there was many in tables accessright, affectation and assignment
  • Supress the entire production database
  • Install a new environment on an other server, with the same version and plugins
  • Dump database structure from this new environment
  • Edit this dump to verify AUTO_INCREMENT and PRIMARY KEY , and set AUTO_INCREMENT=1 for all
  • Import this "modified" structure dump in my production environment
  • Import the data dump modified in this new "structure"
  • Verification
Everithing is operationnel again (I lost some assignments (probably those with an id=0))
Now I will do tests to try to understand what's happend ( problem during an update from a version to another ? other tihings ?) : I tell you more in a few days.
Thanks for help
Damien
25 Mar 2017 16:34 #5 by babynus
Happy to know your retrieved your data.
I am interested in cause if you find it, possibly to post a hint to avoid this happen for other users.
27 Mar 2017 11:57 #6 by dnaton
After some tests, PhPMyAdmin (version 4.3.13) seems to be the responsible.
If I export the structure (or structure and data) of my Database with this version, I don't have the notion of Primary key and AUTO_INCREMENT :blink:
CREATE TABLE IF NOT EXISTS `prjaccessprofile` (
  `id` int(12) unsigned NOT NULL,
  `name` varchar(100) DEFAULT NULL,
  `description` mediumtext,
  `idAccessScopeRead` int(12) DEFAULT NULL,
  `idAccessScopeCreate` int(12) DEFAULT NULL,
  `idAccessScopeUpdate` int(12) DEFAULT NULL,
  `idAccessScopeDelete` int(12) DEFAULT NULL,
  `sortOrder` int(3) DEFAULT NULL,
  `idle` int(1) unsigned DEFAULT '0'
) ENGINE=InnoDB AUTO_INCREMENT=14 DEFAULT CHARSET=utf8
The same table, with an export with an other version of PhpMyAdmin (here an older version 4.1.6) give this result, correct
  `idle` int(1) unsigned DEFAULT '0',
  PRIMARY KEY (`id`)
) ENGINE=InnoDB  DEFAULT CHARSET=utf8 AUTO_INCREMENT=14 ;
My production environment is in version 4.3.13 and my test environment is in 4.1.6.
Before any change of version, I make a backup (normal :) ), with a dump executed from PhpMyAdmin (3 dumps : structure, data, structure and data).
Few weeks ago, the update was not good (problem with formatting - see ticket in the forum). so I restored my precedent database version......and the problem come from this restoration
The dump did'nt have primary key and AUTO_INCREMENT and my base was corrupted :woohoo:
I can reproduce this problemon all my test environment. I'm interested to know if other people can also reproduce it ?
Damien
