- Thank you received: 0
Yes.Should all tables have the value 'AUTO_INCREMENT" ?
This is not normal. All should have AUTO_INCREMENT on id.And If I look for a new install of Projeqtor, there are table with and table without.
This seem to be a solution.Is it a stupidity if I "force" this value AUTO_INCREMENT to all tables ?
CREATE TABLE IF NOT EXISTS `prjaccessprofile` (
`id` int(12) unsigned NOT NULL,
`name` varchar(100) DEFAULT NULL,
`description` mediumtext,
`idAccessScopeRead` int(12) DEFAULT NULL,
`idAccessScopeCreate` int(12) DEFAULT NULL,
`idAccessScopeUpdate` int(12) DEFAULT NULL,
`idAccessScopeDelete` int(12) DEFAULT NULL,
`sortOrder` int(3) DEFAULT NULL,
`idle` int(1) unsigned DEFAULT '0'
) ENGINE=InnoDB AUTO_INCREMENT=14 DEFAULT CHARSET=utf8CREATE TABLE IF NOT EXISTS `prjaccessprofile` (
`idle` int(1) unsigned DEFAULT '0',
PRIMARY KEY (`id`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8 AUTO_INCREMENT=14 ;Please Log in or Create an account to join the conversation.
