ProjeQtOr free project management software - Problem with user access rights - ProjeQtOr
14 Mar 2017 10:22 #1 by Poelstra
I've some problems giving a user the correct access rights. Any help would be appreciated.
I've the following project structure (showing also the profile of the user for the project)
Project 1 (Project Member)
-Project 2 (Project Member)
--Project 3 (Project Leader)
In the 'Planning' form when he selects any project he gets the following message:
You don't have rights to access this Project.
Any subactivities that he selects are shown fine (even from projects he is not allocated to), although he is not able to create any new activities.
The 'Access to data (project dependant)' form show that a 'Project leader' is a 'Manager' for both 'Projects' and 'Activities'.
How can I find out why access is denied? And what should I change to make sure that this user has access to Project 3?
Thanks in advance.
Kind regards,
Remco Poelstra
14 Mar 2017 14:10 #2 by babynus
I thought is was an issue fixed in V6.1.2...
Which version are you using ?
14 Mar 2017 14:13 #3 by Poelstra
Thanks for your reply.
I'm running v6.1.2
Kind regards,
Remco Poelstra
14 Mar 2017 19:54 #4 by babynus
Could not reproduce.
I set the use case in demo.projector.org for user manager (you can connect with password manager)
Connected as manager, you can :
- not see Project 1 (you are member only)
- not see Project 2 (you are member only)
- see and change Project 3 (you are project leader)
- see and change any activity on these projects, as members and leaders can both do this
So for me there is no issue
15 Mar 2017 09:06 #5 by Poelstra
I can't reproduce in the demo database neither. I've attached the projects export from my database. Maybe that will allow the bug to be reproduced.
I've been poking around a bit, so the user now has the following allocated profiles:
Project ID,Profile
4, member
5, member
7, member
8, leader
9, leader
20, leader
All projects show the lock icon.
I'm not sure whether it's a related bug or by design, but even from projects to which he has no allocation at all, he can still see any activities even from sub-projects. I've also attached a screenshot of the structure.
File Attachment:
File Name: export_Pro....csv.txt
File Size:5 KB
Kind regards,
Remco Poelstra
15 Mar 2017 09:15 #6 by Poelstra
I noticed another thing that's probably related:
My projects menu (the top) shows like this:
Attachment not found
His projects menu (the top) shows like this:
Which is understandable as he has nothing to do with the templates.
But his project's view shows only this:
So, there is only a project he is not part of, and doesn't show the projects he's allocated to...
Time to create page: 0.062 seconds
