ProjeQtOr free project management software - Strange display on screen "Project" - ProjeQtOr
02 Mar 2017 10:59 #1 by dnaton
since the upgrade in 6.1.1, I remark a strange display in the project screen
In the section named "Version liées à ce projet", I have linked element
In the section named "Elements liés", I have a field name "Categorie" but not the possibility to create a linked element
The two sections below "Affectations" have strange name
Have any other the same problem ?
Damien
02 Mar 2017 11:14 #2 by krowry
Hello ,
Strange name come from i18n().
It's because this name [sectionProductproject_products] is not found on your lang.xls.
You have change everything on objectDetail.php
02 Mar 2017 11:18 #3 by dnaton
Hello Krowry,
Thanks for the quicly answer :-)
Is it not possible to update the lang file ? It would be better for the future, no ?
And for the two others questions . It's come from the lang file too ?
Damien
02 Mar 2017 11:26 - 02 Mar 2017 11:28 #4 by krowry
Oh no , the problem does not come from lang.xls , your problem come from the plugin customization of screen ...
Your two problem come from the plugin customization .
Can you give us your file in model/custom/project.php ?
Last edit: 02 Mar 2017 11:28 by krowry.
02 Mar 2017 11:36 #5 by dnaton
The file is in attchment below.
Damien
02 Mar 2017 16:17 #6 by krowry
We will evaluate this and we will return to you.
