ProjeQtOr free project management software - Strange display on screen "Project" - Page 2 - ProjeQtOr
02 Mar 2017 21:11 - 05 Mar 2017 11:47 #7 by babynus
It should be better with this version (see attached)
Replace your file /model/custom/Project.php with attached one (after unzipping ;) )
EDIT [2017-03-05] : file attached modified.
(fix was not complete)
Last edit: 05 Mar 2017 11:47 by babynus.
06 Mar 2017 17:28 - 06 Mar 2017 17:35 #8 by dnaton
I copied the new project.php fil on model/custom, in replacement of the old but nothing has changed : it's the same problem.
Damien
Last edit: 06 Mar 2017 17:35 by dnaton.
06 Mar 2017 17:42 #9 by dnaton
another strange thing (i'm sorry :( )
When I have a project with Product and and product version, the "strange" section name display the product and product version but the "correct sections" don't display anything :-(
Damien
06 Mar 2017 20:18 #10 by babynus
Stranger, as I tested it and got good fixing...
Are you sure you correctly copied and unzipped file ?
07 Mar 2017 10:58 #11 by dnaton
Hello Babynus,
It's ok with the new project.php version you post after the first I downloaded.
Damien
