Except a cache issue, I cannot guess what issue is...
What you can possibly try is :
1) test new install and test, with brand new data if issue occurs or not
2) then import your data in this new instance and test again
Give result so we can find out if issue is due to code/config or due to data
ok - i set up a completly new vm with ubuntu LAMP 16.4server - installed projeqtor ProjeQtOr V6.1.0 (160) - chmod and chown the needed Directory. installed mbstring, gd and XML additionally. upgraded database on first Login.
with the completly new empty projeqtor i created an empty Project only named "test" - Content "test". next step was creating a test case only named "test" Project "test" description "test". after that i created a test session, same here: Name: "test", Project "test" description "test". press "save". add the test case after Auto save i click on the green "OK" and then the error appears again "Some field contains invalid data. Please correct first".
the same procedure in demo works without any issues.
maybe a Linux Problem? or a Problem with some rights or configurations?
First, this is not a Linux issue : Demo runs on Linux (Ubuntu).
Then, I tried again, executing your use case step by step, and not produce the isse.
All runs fine for me.
So it is difficult to analyse without reproduction.
Most probable possibility I can imagine is a cache issue.
Please try after completely clearing browser cache (through parameters, not only F5)
Also try with another browser you never used before.
I deleted the whole Cache via Parameters. Still the same issue. We tested on 2 different Laptops and the issue is reproducable. And at last i tested the following browser:
Internet Explorer 11
Google Chrome 56
Firefox 31
Vivaldi 1.7
still the same issue.
are there any needed fields or required data which is mandatory for closing testcases or anything else? maybe some Connections, Parameters or configurations related to Projects or Test Cases which i may have missed?
iam completly clueless :-/ we will run projeqtor in our Company but this seems to be the showstopper.
