i chmod and chown rekursive the whole Directory to WWW-data, just for Logical understanding, what happened with the test-cases, which modules or directories are affected? it is Kind a weird because the test Environment works and 2 different Environments in our Company are having some Troubles, i'm trying to figure it out but totally have no clue
ok guess what, i figured out which data was needed for Setting the testrun to "success". he definitly Needs a ticket data. without ticket he is not able to mark the testrun. this is weird because on your demo Version i did not Need any ticket data attached to the testrun.
if i put in an incorrect value in php table for test case runs in the field ticket, he is also able to mark the test case with success. and if i put in a random ticket in projeqtor self, with edit Options, he is too. i thought putting in connected tickets was only needed for failed Tests? otherwise it works on your side without ticket data informations. maybe you have a clue what went wrong in our 2 different projeqtor Environments. on the other completly new desinged appliance ticket-id is needed too for marking testruns "success".
In fact, I thing that on Demo the test session is defined on project having some tickets, so ticket list is not empty and ticket is set to first one (but this value is not used on "Passed" case). In your case, Ticket list may be empty, so not defaut value...
We'll fix that !
EDIT : I could reproduce, so now fixing will be easy
