ProjeQtOr free project management software - Resource Capacity planning - Page 2 - ProjeQtOr
05 Oct 2016 16:06 #7 by babynus
Replied by babynus on topic Resource Capacity planning
It means that i can have a forecast view of my team work, in relation with the capacity, time
This is possible with defined planning.
-the ability to create and join a supply and demand forecast that highlights future resource gaps and surplus.
Yes, this is possible, for instance using some specific planninng mode tpo reserve availability for resources.
-flexibility of performing what-if scenario analysis to find the optimal solution set.
No, this is not possible.
-ability to create resource plans to resolve future resource imbalances.
Yes, but you must keep in mind that, opposit to MS-Project, ProjeQtOr planning never "over-loads" resources.
But you can see future "availability" of resources (periods when planning is not fuill for resource)
05 Oct 2016 16:12 #8 by sendo12
Replied by sendo12 on topic Resource Capacity planning
Oh thanks now things become more clear, one thing, you said "This is possible with defined planning.", you mean that it's possible to do custom planning ? maybe i understood wrong but this would be insane, how do i manage to do defined planning ?
05 Oct 2016 16:16 #9 by babynus
see team work capacity over a month for exemple
Reports => Planning => Colored monthly resource planning (you need to define a color on projects...)
Reports => Planning => Monthly planning Resource/Project (for detail day by day)
Reports => Planning => Work plan per month (for monthly work capacity)
Reports => Planning => Availability synthesis (to see left availability per month for each resource)
worked 1,5 work unit on somthing that he should have finished in just 1work unit, is it possible to have some kind of grapic to show that ?
Reports => Planning => Work synthesis per activity
Reports => Real work => Work synthesis per activity (same with somle smileys
05 Oct 2016 16:21 #10 by sendo12
Okey thank you very much :), this is very helpful, maybe i'll have some questions later, thanks !
05 Oct 2016 16:26 #11 by babynus
No, you cannot define "custom" planning manually.
But you can play with different planning modes.
For instance "regular between dates" can help you reserve some capacity to treat forcasted elements not received yet (for instance work on tickets that are not received yet)
05 Oct 2016 17:05 #12 by sendo12
Okey, where can i find "regular between dates"? the functionality seems really interesting.
