ProjeQtOr free project management software - Resource Capacity planning - ProjeQtOr
05 Oct 2016 11:24 #1 by sendo12
Hello, working with jira in my company, i had to find another solution for project management, i found projeqtor very interesting so i wanted to know if it was possible to do capacity planning with it, thanks in advance.
05 Oct 2016 14:02 #2 by krowry
Replied by krowry on topic Resource Capacity planning
Hello ,
What means' Capacity planning ' for you ?
05 Oct 2016 14:11 #3 by climb4fun
Hi Sendo,
if you would like to have an overview of plan capacity and how many of this plan is already assigned and/or used, then I can say, I used this in the past in this way. You will find it in reporting - planning - ... here are several reports, please figure out, which suits for you. --> You can quickly test in DEMO on this web site.
Klaus
05 Oct 2016 15:03 #4 by sendo12
Replied by sendo12 on topic Resource Capacity planning
It means that i can have a forecast view of my team work, in relation with the capacity, time .., i would say :
-the ability to create and join a supply and demand forecast that highlights future resource gaps and surplus.
-flexibility of performing what-if scenario analysis to find the optimal solution set.
-ability to create resource plans to resolve future resource imbalances.
must admist that it is a complex ability, even i don't really understand it well, if you've somthing that can help understand more you're more than welcome, thanks for responds
05 Oct 2016 15:13 #5 by climb4fun
What you describe sounds like it works in MS Project. I didn't find this flexible way to lift and shift resource allocations. But an proper resource allocation view is very well served with ProjeQtor. Give a try to the reports.
05 Oct 2016 15:28 #6 by sendo12
indeed reports are very useful, but i'am searching right now and i don't find something related to forcast, it would be very useful to see team work capacity over a month for exemple, lets say we're monday someone worked 1,5 work unit on somthing that he should have finished in just 1work unit, is it possible to have some kind of grapic to show that ?
