ProjeQtOr free project management software - Attachment section does not appear after upload - Page 2 - ProjeQtOr
17 Nov 2015 20:36 #7 by mendo15
When adding attachment:
Object { message: "Unable to load ../tool/saveDataToSe…", stack: ".cache["dojo/errors/create"]/</</_4…", response: Object, status: 0, responseText: "", xhr: XMLHttpRequest } dojo.js:15:102025
.cache["dojo/_base/xhr"]/</_3c4() dojo.js:15
.cache["dojo/_base/xhr"]/</dojo._ioSetArgs/<() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
.cache["dojo/_base/Deferred"]/</dojo.Deferred/this.errback() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
.cache["dojo/_base/xhr"]/</dojo.xhr/<() dojo.js:15
.cache["dojo/Deferred"]/</_3e7() dojo.js:15
.cache["dojo/Deferred"]/</_3e1() dojo.js:15
.cache["dojo/Deferred"]/</_3e6/this.reject() dojo.js:15
.cache["dojo/Deferred"]/</_3ed() dojo.js:15
_31b() dojo.js:15
_328() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_31b() dojo.js:15
_328() dojo.js:15
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help xhr.spec.whatwg.org/ dojo.js:15:0
Use of getAttributeNode() is deprecated. Use getAttribute() instead. dojo.js:15:0
Object { message: "Unable to load objectDetail.php?ref…", stack: ".cache["dojo/errors/create"]/</</_4…", response: Object, status: 500, responseText: "<input type="hidden" id="attachment…", xhr: XMLHttpRequest } dojo.js:15:102025
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_31b() dojo.js:15
_327()
17 Nov 2015 20:39 #8 by mendo15
When adding an attachment:
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_31b() dojo.js:15
_328() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_31b() dojo.js:15
_328() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_31b() dojo.js:15
_327()
19 Nov 2015 20:17 #9 by mendo15
Is this issue being worked on?
Thank you.
25 Nov 2015 09:17 #10 by babynus
Could you please post ProjeQtOr log file ?
26 Nov 2015 18:51 - 09 Dec 2015 21:33 #11 by mendo15
Log files compressed and attached.
Thank you.
Last edit: 09 Dec 2015 21:33 by mendo15.
26 Nov 2015 19:11 #12 by babynus
Your log files only shows bad configuration for SMTP server.
Your configuration for smtp host = localhost points to no SMTP server.
You'd better remove this configuration (keep parameter blank)
There is no other error that could explain the behavior you get.
Try and disable or remove all plugins and extensions on your browsers.
Sometimes, some extensions set a mess in the pages.
For instance, Skype ClickToCall is very well know to set a mess in web applications, trying to replace all what looks like a phone number as a click to call link.
Youy can also try and install V5.1.4 (under deployment when writing this message, you may wait for few minutes before it is available).
