ProjeQtOr free project management software - Attachment section does not appear after upload - Page 3 - ProjeQtOr
03 Dec 2015 14:50 #13 by mendo15
I've tried removing all extensions and problem still occurs. However when using projeqtor with a larger screen, the problem seems to disappear?
03 Dec 2015 15:13 #14 by babynus
What is screen resolution of screen when error occurs ?
Is there a browser zoom ratio applied ?
Which browser is used ?
03 Dec 2015 17:22 #15 by mendo15
Using:
Firefox (v 42.0)
Screen Resolution: 1600 x 900
Browser zool level: 100%
03 Dec 2015 19:52 #16 by babynus
Do what do you mean with
Could you explain more explicitly (as I cannot reproduce, I need more hints to fix)
03 Dec 2015 20:15 - 04 Dec 2015 13:20 #17 by mendo15
I have a monitor attached (1920 x 1080) to my computer.
When bringing the browser window to this monitor I do not experience the issue. However when it is on my smaller screen (1600 x 900) this issue occurs:
As you can see there are 7 attachments, and I only can see 1.
I was able to reproduce the problem on the 1920 x 1080 screen. So my issue isn't solved. I am on v5.1.4 btw.
Last edit: 04 Dec 2015 13:20 by mendo15.
04 Dec 2015 08:56 #18 by babynus
Can you show print screen with the 7 ataached files
Maybe something in the name or else xould give me a hint...
This issue is still very strange to me : I cannot reproduce on my PC, using default resolution of 1600x900 (the one facing issue on your side)
