ProjeQtOr free project management software - [SOLVED] Teams are not working at fully time on project - Page 2 - ProjeQtOr
19 Oct 2015 16:14 #7 by babynus
Because no resource if affected to the project : you did not define the project team.
First affect resources to the project.
19 Oct 2015 16:35 #8 by El Wallos
Ah ok, for example, I affect 100% on the project screen and if I affect on the task 40%, so the ressource will work 0.4 day every day of the week, is it right?
Je mets la traduction en Francais pour éviter les quiproquos avec l'anglais:
Si j'alloue 100% de la ressource au projet et 40% sur la partie de la tache (activité), alors la ressource travaillera 0.4 jour sur cette tache tous les jpours de la semaine.
If I mix, I affect 80% on the project screen and if I affect on the task 40%, so the ressource will work 0.4 day during 4 days every week.
Si je mélange les deux, et j'alloue 80% de la ressource au projet et 40% sur la partie de la tache (activité), alors la ressource travaillera 0.4 jour sur cette tache pendant 4 jours de la semaine.
Dis moi si j'ai bien compris..
19 Oct 2015 16:52 #9 by babynus
No.
Resource will work 0,4 days each day, with a maximum of 4 days of work per week on the project. In your case, the affectation rate has no effect as 0,4 x 5 = 2days, which is less than limit of 4 days. In your case, affectation rate to project will have effects only if resource is assigned to other tasks on same project.
19 Oct 2015 17:10 #10 by El Wallos
Sorry but I don't understand. Your answer was for which ratio?
Could you explain me again with this number?
Project Screen: 100% Activity Screen: 40% ----> ressource will work ...
Project Screen: 80% Activity Screen: 40% ----> ressource will work ...
because I don't understand what is the impact of the Project Screen Ratio.
19 Oct 2015 17:40 #11 by babynus
Hope it will be more clear with a small tables with all possibilities for project affectation rate combined with activitie assignment rate for values 100%, 80% and 40%
The following user(s) said Thank You: fmoyer, El Wallos
20 Oct 2015 09:25 #12 by El Wallos
Thanks a lot Babynus, sometimes, one image explains better than 1000 words B)
